Expand the connectivity of your USB-C laptop with this new generation USB-C Gen 2 hub offering 10Gbps supporting greater bandwidth to connected devices and faster data transfer speeds. This bus-powered 4-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding one USB-C port and three USB-A ports, so you can quickly connect more USB devices.
This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories. The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus powered devices at one time with the total available power dependent on the connected host.
The extended length attached cable of 9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug and play installation.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. You can connect flash drives, video capture devices and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 4-port USB Type-C hub enhances your productivity, giving you the connections you need while you work.
Versatile connectivity options
Equipped with four ports, this hub allows for multiple devices to be connected simultaneously, enhancing productivity and convenience. -
Robust compatibility
Supports various USB standards including USB 3.0 and USB 3.2 Gen 2, ensuring broad device compatibility for seamless connections. -
Durable and resilient design
Operates efficiently in temperatures ranging from 0 °C to 50 °C and stores safely from -20 °C to 70 °C, making it suitable for various environments. -
User-friendly Plug-and-Play setup
The Plug-and-Play functionality eliminates the need for complex installation processes, allowing for immediate use upon connection. -
Efficient data transfer
With full duplex mode and auto-uplink features, this hub ensures reliable and speedy data transfer for all connected devices.
- StarTech.com 4 Port USB C Hub w/ 3x USB A & 1x USB C, SuperSpeed 10Gbps USB Type-C, USB 3.1/3.2 Gen 2 Hub, USB Bus Powered, Compact USB-C to USB Adapter Hub, Portable/Laptop Hub, Aluminum - Windows/macOS/Linux (HB31C3A1CB) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 1 x USB-C + 3 x USB 3.1
- Auto-uplink (auto MDI/MDI-X), full duplex mode, USB powered, USB Pass-Through
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
- 4.5 cm x 10.5 cm x 1.6 cm
- 48 g
- Black, space grey
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Google Chrome OS 61, Apple MacOS X 10.10 - 10.13, Linux Kernel 4.x LTS, Ubuntu 14.04.x LTS, Ubuntu 16.04.x LTS, Android 8.x
- 2-year warranty
- Designed For
- P/N: PEXUSB321C
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Processor
- X Realtek Semiconductor RTS5423
- 1 x USB 3.1 Gen 2 Type C , 3 x USB 3.1 Gen 2 Type A
- Black, space grey
- Cables Included
- 1 x USB-C cable - 25 cm
- Plug and Play, FCC, REACH, UASP (USB Attached SCSI Protocol)
- OS Required
- 4.5 cm
- 10.5 cm
- 1.6 cm
- 48 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Designed For
- P/N: PEXUSB321C
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £7.96 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.06 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.29 |
StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.05 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.63 |
StarTech.com 0.5m USB 3.1 C - Micro B Cable | In Stock | £10.54 |
StarTech.com 0.5m USB C Cable - USB 3.1 | In Stock | £14.73 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £16.99 |
StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter | In Stock | £66.45 |
StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C | In Stock | £43.84 |
StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 | In Stock | £39.94 |
StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable | In Stock | £47.64 |
StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable | In Stock | £28.04 |
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £115.92 |
StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £120.71 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £38.20 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £32.62 |
StarTech.com Industrial USB 2.0 Hub | In Stock | £115.92 |
StarTech.com 10-Port USB-C Hub Self-Powered | In Stock | £115.46 |
StarTech.com 7-Port USB-C Hub, Self-Powered | In Stock | £106.95 |
