StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C
Quicklinx: FMHWWS00 Mfr#: HB31C2A2CB
Type: USB
Ports: 4
Data Transfer Rate: 10Gbps
Managed: No
POE: No
Hurry, only 1 left in stock!
£43.29 ex VAT
£51.94 inc VAT
Expand the connectivity of your USB-C laptop with this new generation USB-C Gen 2 hub offering 10 Gbps supporting greater bandwidth to connected devices and faster data transfer speeds. This bus-powered 4-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding two USB-C port and two USB-A ports, so you can quickly connect more USB devices.
This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories. The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus-powered devices at one time with the total available power dependent on the connected host.
The extended length attached cable of 9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug and play installation.
With ports for both USB-C and USB-A peripherals, this hub is backward compatible supporting both legacy and new USB devices. You can connect flash drives, video capture devices, and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 4-port USB Type-C hub enhances your productivity, giving you the connections you need while you work.
  • Versatile connectivity options
    Equipped with two USB-C and two USB 3.1 Gen 2 ports, this hub provides a variety of connection types suitable for different devices, enhancing flexibility in usage.
  • Compact and efficient design
    This hub's desktop form factor allows for integration into any workspace without taking up excessive space, making it a practical addition to office setups.
  • Broad compatibility standards
    Designed to function with USB 1.1, USB 2.0, USB 3.0, and USB 3.2 Gen 2 standards, it ensures wide-ranging compatibility across numerous devices.
  • Environmentally-friendly compliance
    The hub meets standards including FCC, RoHS, and REACH, underscoring commitment to environmental responsibility and user safety.
  • Robust operating conditions
    This hub is engineered to perform efficiently within a temperature range of 0°C to 50°C and can withstand humidity levels up to 95%.
StarTech.com 4 Port USB C Hub w/ 2x USB A & 2x USB C, SuperSpeed 10Gbps USB Type-C 3.1/3.2 Gen 2 Hub, USB Bus Powered, Portable USB-C to USB Adapter Hub, Aluminum, 9.8" (25cm) Cable - Windows/macOS/Linux - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
2 x USB-C + 2 x USB 3.1 Gen 2
USB powered
USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 2
4.5 cm x 10.5 cm x 1.6 cm
190 g
Black, space grey
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows Server 2016, Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Microsoft Windows Server 2019, Android 9.0 (Pie), Apple MacOS X 10.10 - 10.14, Linux Kernel 4.x- 5.x LTS, Ubuntu 12.04 - 19.04 LTS, Google Chrome OS 69
P/N: PEXUSB321C
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X VIA Labs / Realtek RTS5423 / VL160
2 x USB 3.1 Gen 2 Type C , 2 x USB 3.1 Gen 2 Type A
Black, space grey
1 x USB-C cable - 25 cm
Plug and Play, FCC, RoHS, REACH, UASP (USB Attached SCSI Protocol)
4.5 cm
10.5 cm
1.6 cm
190 g
Shipping Width
14.4 cm
Shipping Depth
20.7 cm
Shipping Height
3.8 cm
Shipping Weight
196 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
FMHW StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
FMHW StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
FMHW StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
FMHW StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.24
FMHW StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.27
FMHW StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.59
FMHW StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.76
FMHW StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £17.60
FMHW StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £32.28
FMHW StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £55.62
FMHW StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £47.36
FMHW StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter In Stock £63.26
FMHW StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £43.29
FMHW StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £38.05
FMHW StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £43.12
FMHW StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.28
FMHW StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £112.74
FMHW StarTech.com 4 Port USB C Hub 10Gbps In Stock £117.38
FMHW StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.06
FMHW StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.91
FMHW StarTech.com Industrial USB 2.0 Hub In Stock £39.99
FMHW StarTech.com 10-Port USB-C Hub Self-Powered In Stock £112.29
FMHW StarTech.com 7-Port USB-C Hub, Self-Powered In Stock £104.01
Type: USB
Ports: 4
Managed: No
POE: No
