The StarTech.com Triple-Monitor USB4 Docking Station offers extensive connectivity options, making it suitable for multitaskers and professionals seeking efficient workspace solutions. With support for up to three displays featuring resolutions up to 4K at 60 Hz, this docking station allows integration of multiple monitors, enhancing productivity and workflow. Equipped with ports including HDMI, DisplayPort, Ethernet, and audio interfaces, it caters to various device connections while delivering high-quality audio and video output. This versatile docking station supports features like wake on LAN and UASP transfer protocol, ensuring performance for data transfers and network connections. Additionally, the USB4 technology enables data transfer speeds up to 40 Gbps, while providing up to 100 W power delivery to charge compatible devices. Compatible with both USB4 and Thunderbolt 4 devices, it provides versatility for both home office and professional setups.
- StarTech.com Triple-Monitor USB4 Docking Station, 4K 60Hz HDMI or DisplayPort, 100W Laptop Charging, 2.5GbE, USB-C Multi-Monitor Dock, Driverless - docking station - USB4 / Thunderbolt 4 - 3 x DP, 3 x HDMI - 1GbE, 2.5GbE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- 3 x DP, 3 x HDMI
- 9.5 cm x 21 cm x 3.4 cm
- 1.057 kg
- Space grey
- Networking
- Gigabit Ethernet, 2.5 Gigabit Ethernet
- Power
- Power adapter AC 110-240 V 180 Watt Power Provided (DC 20 V)
- 3-year warranty
- Product Type
- Docking station
- 9.5 cm
- 21 cm
- 3.4 cm
- 1.057 kg
- Enclosure Colour
- Space grey
Video
- Max Resolution Details
- 3840 x 2160, 4K - 144 Hz (DisplayPort only) , 3810 x 2160 - 60 Hz (HDMI)
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- USB 3.2 Gen 1, USB 3.2 Gen 2, USB4
- 3 x display / video - HDMI - 19 pin HDMI Type A , 3 x display / video - DisplayPort - 20 pin DisplayPort , 4 x USB 3.2 Gen 2 - 9 pin USB Type A , 2 x USB 3.2 Gen 2 - 24 pin USB-C , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm 4-pole , 1 x network - 10Base-T/100Base-T/1000Base-T/2500Base-T - RJ-45
- Cables Included
- 1 x USB4 cable - external - 1 m
- 100W power delivery, wake on LAN, Preboot Execution Environment (PXE) support, up to 40Gbps data transfer, UASP transfer protocol, full duplex support
- Security Slot Type
- Kensington nano security slot / Kensington security slot
- Plug and Play, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 3.0, BC1.2
- Power Device
- Power adapter
- Voltage Required
- AC 110-240 V
- Power Provided
- 180 Watt
- Voltage Provided
- DC 20 V
- OS Required
- Google Chrome OS, Microsoft Windows 10 / 11
- Limited warranty - 3 years
- Shipping Width
- 14.5 cm
- Shipping Depth
- 23.5 cm
- Shipping Height
- 9.9 cm
- Shipping Weight
- 1.4 kg
- 0 °C
- 40 °C
StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla | In Stock | £9.29 |
StarTech.com 3ft Premium Certified HDMI 2.0 | In Stock | £10.97 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £12.98 |
StarTech.com 10ft Premium Certified HDMI | In Stock | £15.57 |
StarTech.com 3x Monitor USB4 Dock, 100W PD
