Connect up to three 4K 60Hz displays (2x DisplayPort and 1x HDMI) through a single USB-C port, while also providing USB-C, USB-A, and Gigabit Ethernet connectivity. Connect up to three 4K 60Hz displays through a single USB Type-C port with uncompressed video powered by your laptop's native GPU. Drive demanding workflows with high-performance visuals and no software compression Features plug-and-play functionality on Windows with no drivers or software required*. It is engineered for scalable, zero-touch rollouts across shared workspaces, corporate environments, and BYOD deployments. This dock is equipped with 4× USB-A 5 Gbps ports and 2× USB-C 10 Gbps ports (including one with 15 W PD), providing support for both legacy peripherals and modern high-throughput devices without compromising performance. A Gigabit Ethernet port ensures a reliable wired network connection. This multi-monitor dock includes built-in lock slots for enhanced physical security and supports Surface or VESA mounting to keep the dock secure and out of the way. Mounting accessories are sold separately (SSPMSUDWM, DOCK-NUC-VESA-MOUNT, SSPMSVESA). Note: Not compatible with macOS or ChromeOS.
- Startech - docking station - USB-C 3.2 Gen 2 - HDMI, 2 x DP - 1GbE
- Product Type
- Docking station - for laptop
- Docking Interface
- USB-C 3.2 Gen 2
- Video Interfaces
- HDMI, 2 x DP
- 19 cm x 7.9 cm x 2.7 cm
- 300 g
- Space grey
- Localisation
- United Kingdom, Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 100-240 V (DC 24 V)
- 3-year warranty
- Product Type
- 19 cm
- 7.9 cm
- 2.7 cm
- 300 g
- Enclosure Colour
- Space grey
- Localisation
Video
- Max Resolution Details
- 4K - 60 Hz (Triple Display (2 x DisplayPort + HDMI))
- Data Link Protocol
- USB 3.2 Gen 2, USB 3.2 Gen 1
- 4 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 with Power Delivery (15 W) - 24 pin USB-C , 2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W) - 24 pin USB-C
- Cables Included
- 1 x USB-C host cable - detachable - 1 m
- Included Accessories
- Power cable (EU), power cable (UK)
- Security lock slot (cable lock sold separately), wake on LAN, Preboot Execution Environment (PXE) support, full duplex support, 15W power delivery, 100W power delivery, triple display support, hub power LED, up to 10Gbps data transfer, 5Gbps data transfer, driverless
- Security Slot Type
- Kensington nano security slot / Kensington security slot
- Plug and Play, FCC, RoHS, WEEE, USB Power Delivery 3.0
- Power Device
- Power adapter
- Voltage Required
- AC 100-240 V
- Voltage Provided
- DC 24 V
- OS Required
- Microsoft Windows 10 / 11, Ubuntu 24.04
- Limited warranty - 3 years
- Shipping Width
- 25 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 5 cm
- Shipping Weight
- 1 kg
- 0 °C
- 70 °C
StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla | In Stock | £9.29 |
StarTech.com USB-C Dock, 2x HDMI, 100W PD | In Stock | £87.84 |
