StarTech.com 3U Wall Mount Vertical Rack
Quicklinx: H2Z2WS00 Mfr#: RK319WALLV2
StarTech.com 3U 19" Fixed Wall Mount Vertical Rack, Patch Panel Bracket Wall Mount for Data/AV/IT/Computer, Vertical Mounting, 3U Rack for Cabinet and Server Room, 150lb (68kg) Capacity (RK319WALLV2)
  • Versatile Design
    Mount the bracket into a wall featuring wood stud construction, where studs are spaced 16in (40.6cm) apart. The patch panel wall mount rack is perfect for SoHo (small office, home office) and other small footprint applications allowing you to vertically mount up to 150lb (68kg) of standard rack equipment into this 14-gauge steel bracket. The mounting holes are positioned 16in (40.6cm) apart, matching the standard for construction framework.
  • Included Hardware
    The vertical wall mount network rack conveniently includes 6x wood screws, 12x M5 square cage nuts, and 12x M5 screws to attach the rack to a wall and mount your equipment. The wall mount vertical rack is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 3U 19" Wall Mount Vertical Rack, Patch Panel Wall Mount Bracket for Data/AV/IT/Computer Equipment, 3U Rack for Cabinet or Server Room, Supports 150lb (68kg) - Mounting Hardware Included (RK319WALLV2) - patch panel bracket (vertical) - 3U
Patch panel bracket (vertical)
Placing / Mounting
Wall mountable
Package Content
12 M5 screws, 12 M5 cage nuts, 6 wood screws, quick start guide
Rack Size
19"
Height (Rack Units)
3U
Product Material
14 gauge steel
50.5 cm x 15.5 cm x 14.9 cm
Square hole, open frame, L-shaped mounting rail profile, 2-post
Placing / Mounting
Wall mountable
Product Material
14 gauge steel
Package Content
Rack Size
19"
Height (Rack Units)
3U
50.5 cm
15.5 cm
14.9 cm
53.2 cm x 17 cm x 17.2 cm
Finish
Powder coat
Weight Limit
68 kg
Mounting Kit
Included
EIA-310-E, REACH, ECA-310-E, ISTA 6
TAA Compliant
Limited warranty: - lifetime , Technical support: assistance - lifetime
