StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket
Quicklinx: 6B9VWS00 Mfr#: RK319WALLV
Product Type: Mounting bracket
25 In Stock
£39.01 ex VAT
£46.81 inc VAT
Mount server, network or telecommunications devices vertically with this 3U wall-mountable rack. The RK319WALLV 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket offers a versatile storage solution, allowing equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with wall) to save space. Alternatively, the 3U bracket can be installed under a desk for horizontal installation, making it easy to access installed equipment directly from your workspace. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Constructed to EIA-310 19in rack standards, the wallmount bracket features a sturdy steel design, perfect for SoHo (small office, home office) environments. The wallmount bracket offers space-saving installation for environments lacking the footprint space for a full size server equipment rack.
Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes (used to mount to a wall or the desk underside) are positioned at exactly 16in apart, matching standard construction framework.
Need more storage space? StarTech.com also offers a RK119WALLV 1U 19in Wallmount Bracket, a RK219WALLV 2U 19in Wallmount Bracket and a RK419WALLV 4U 19in Wallmount Bracket.
  • Durable material
    Made from steel, this mounting bracket offers strength and longevity for dependable use.
  • Easy installation
    The included mounting kit simplifies the setup process, allowing for quick and hassle-free installation on walls.
  • Compliant standards
    Meets UL and RoHS standards, ensuring safety and environmental compliance.
  • Space-efficient design
    With a height of 3 rack units, this bracket helps maximize vertical space while keeping equipment organized.
  • Versatile compatibility
    Designed for 19-inch rack size, it is suitable for various networking equipment applications.
StarTech.com 3U Wall Mount Patch Panel Bracket - 19 in - Steel Vertical Patch Panel Mounting Bracket for Networking Equipment (RK319WALLV) - mounting bracket - 3U
Mounting bracket
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
3U
Product Material
Steel
5 cm x 14.9 cm x 15.1 cm
0.94 kg
Mounting bracket
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
3U
5 cm
14.9 cm
15.1 cm
0.94 kg
Mounting Kit
Included
UL, RoHS
Limited warranty: - lifetime
6B9V StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £40.61
6B9V StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £34.65
6B9V StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £39.01
6B9V StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
6B9V StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
6B9V StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £48.26
6B9V StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels In Stock £16.23
6B9V StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
6B9V StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
6B9V StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
6B9V StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
6B9V StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £129.80
6B9V StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £31.67
6B9V StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
6B9V StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
6B9V StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
6B9V StarTech.com 100 Pkg M5 Cage Nuts In Stock £25.96
6B9V StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
6B9V StarTech.com 100 Pkg M5 Cage Nuts In Stock £29.98
6B9V StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.03
6B9V StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
6B9V StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
6B9V StarTech.com 100 Pkg M5 Mounting Screws In Stock £28.96
6B9V StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
6B9V StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.90
6B9V StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.56
6B9V StarTech.com 19in Cable Management Panel In Stock £23.58
6B9V StarTech.com 18U Server Rack Enclosure In Stock £369.77
6B9V StarTech.com 6U Wall-Mount Rack Cabinet In Stock £148.99
6B9V StarTech.com 26U Server Rack Enclosure In Stock £463.46
6B9V StarTech.com 9U Wall-Mount Rack Cabinet In Stock £174.53
6B9V StarTech.com 9U Wall-Mount Rack Cabinet In Stock £193.99
6B9V StarTech.com 12U Server Rack Enclosure In Stock £330.35
6B9V StarTech.com 12U Server Rack Enclosure In Stock £280.72
6B9V StarTech.com 15U Server Rack Enclosure In Stock £313.10
6B9V StarTech.com 12U Server Rack Enclosure In Stock £375.79
6B9V StarTech.com M6 Mounting Screws 50Pack In Stock £16.79
