StarTech.com 3PT M.2 SSD Card - PCIe 3.0
Quicklinx: C9WZWS00 Mfr#: PEXM2SAT32N1
Type: Interface Adapter
Compatibility: Mac, PC
Interface: PCI Express
£28.55 ex VAT
£34.26 inc VAT
Mount both PCIe (NVMe) and SATA based M.2 SSDs inside your computer using this PCI Express adapter card. This 3-port M.2 SSD adapter card is one of the only cards that supports both PCIe and SATA-based M.2 SSDs (solid-state drives). It's a versatile way to expand the overall storage capacity of your desktop PC or server. Plus, because it supports a high-speed PCIe M.2 drive, you can increase the speed and performance of your computer.
If you need a simple and discreet way to expand your computer's storage, then this card can help. The card provides a platform for adding up to three M.2 SSDs to virtually any computer that has a PCIe slot. It supports common M.2 SATA SSDs, as well as newer high-performance M.2 PCIe drives. Now, you have a simple and effective way to expand the storage of your computer, regardless of the M.2 drive types you are using.
When you couple this card with a PCI Express based M.2 drive, you can give your computer's performance a noticeable speed boost. With support for PCI Express 3.0 (up to approximately 40Gbps), you can install the latest high-performance M.2 PCIe SSDs inside your computer. With faster performance, you can get more work done in less time.
Due to their performance and size advantages, M.2 drives are commonly used in laptops. If your laptop has failed, but its M.2 drive is still functional, then this card can help with data recovery. Once the M.2 drive is installed and the data recovery is complete, you can continue to use the drive for storage and backup purposes.
This M.2 card lets you take advantage of the size and performance benefits of NGFF M.2 SSDs. M.2 drives are smaller than typical platter drives or mSATA-based SSDs, so you can install them in small form-factor PCs and servers, or in tighter areas within your computer case.
You can rest assured that your M.2 SSDs are compatible with the adapter card. It supports the most common drive sizes, including, 2280, 2260, 2242 and 2230.
Startech 3-port M.2 SSD (NGFF) Adapter Card - Supports 1x PCIe (NVMe) M.2 SSD, 2x SATA III M.2 SSDs - PCIe 3.0 Adapter (PEXM2SAT32N1) - interface adapter - M.2 Card / SATA 6Gb/s - PCIe 3.0
Interface adapter - internal
Bus Type
PCIe 3.0
Compatible Bay
1
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
2 cm x 10 cm x 12 cm
100 g
M.2
Host Bus
PCIe 3.0
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
3 x M.2 Card - M.2 Card
2 x SATA 6Gb/s - 7 pin Serial ATA
Compatible Bay
1 x internal
Low-profile bracket, screwdriver, M.2 screws
Supports ATA/ATAPI packet command set
MTBF
50,000 hours
FCC, RoHS, RCM
2 cm
10 cm
12 cm
100 g
5 °C
50 °C
20 - 80% (non-condensing)
C9WZ StarTech.com 24" Serial ATA Cable In Stock £5.28
C9WZ StarTech.com 12in Latching SATA Cable In Stock £6.16
C9WZ StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
C9WZ StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering In Stock £69.40
C9WZ StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
C9WZ StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
C9WZ StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £28.55
C9WZ StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £40.35
C9WZ StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £45.80
Compatibility: Mac
Compatibility: PC
