StarTech.com 3m White USB-C Charging Cable
Quicklinx: HVMMWS00 Mfr#: USB2CC3MWHE
More than 50 In Stock
£6.79 ex VAT
£8.14 inc VAT
Discover the StarTech.com 3m White USB-C Charging Cable, a versatile and durable solution for all your charging needs. This cable supports Power Delivery 2.0 and USB Power Delivery up to 60 W, allowing for fast and efficient charging of your devices. With a data transfer rate of 480 Mbps, it also facilitates quick syncing of files, photos, and videos. The cable is designed for longevity, featuring a polyamide housing, a minimum bend radius of 8 mm, and a 10,000 insertions lifespan. It also includes EMI protection and aluminum mylar foil with braid shielding material to protect against electromagnetic interference, ensuring a stable and reliable connection. Whether at home, in the office, or on-the-go, this USB-C cable is the perfect choice for those seeking a high-quality, durable charging solution.
  • Efficient power delivery
    Equipped with Power Delivery 2.0 support and USB Power Delivery up to 60 W, this USB-C charging cable ensures your devices charge quickly and safely, minimizing downtime and maximizing productivity.
  • Durable design
    Featuring a robust polyamide housing, a minimum bend radius of 8 mm, and a 10,000 insertions lifespan, this cable is designed for durability and long-term use, making it a reliable choice for all your charging needs.
  • High-speed data transfer
    With a 480 Mbps data rate, this cable offers fast syncing capabilities, allowing you to transfer files, photos, and videos quickly between devices without any lag.
  • Enhanced protection
    The cable's EMI protection and aluminum mylar foil with braid shielding material safeguard your devices against electromagnetic interference, ensuring a stable connection and charge every time.
StarTech.com 3m White USB-C Charging Cable, USB C Cable, 60W 3A PD - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
USB-C cable
Shielded
Halogen-free, passive cable, USB Power Delivery (60W), Power Delivery 2.0 support, sync and charge, strain relief, EMI protection, 480 Mbps data rate, polyamide housing, fast charging support, 10000 insertions lifespan, minimum bend radius 8 mm
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
5 / 9 / 12 / 15 / 20 V
Rated Current
3 A
USB / USB 2.0
White
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
24/30
Rated Voltage
Rated Current
3 A
Plated Connector
Nickel
Length
3 m
Outside Diameter
3.5 mm
White
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
90 g
