StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F
Quicklinx: 8Y6FWS00 Mfr#: USBEXTPAA3MW
Length: 3m
More than 50 in stock
£5.23 ex VAT
£6.27 inc VAT
Extend the length of your USB 2.0 cable by up to 3m. The USBEXTPAA3MW 3m White USB 2.0 Extension Cable features a USB ''A'' male connector and a USB ''A'' female connector, enabling you to extend the connection distance between your USB 2.0 devices by up to 1-meter - allowing for better placement of your peripheral devices, or adding flexibility to your existing USB ports.
The cable features thin USB connector moldings which allow you to simplify your connections, and plug into tight fitting locations.
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F - USB extension cable - 3 m
USB extension cable
Double shielded
Molded, strain relief
Length
3 m
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
White
P/N: MSDREADU2OTG, USBEXTPAA1MW, USBEXTPAA2MW, USBPAUB1MW, USBPAUB2MW, USBPAUB50CMW, UUSBOTG
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
3 m
White
Connector
USB / USB 2.0, RoHS
8Y6F StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £5.23
8Y6F StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £4.50
8Y6F StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F In Stock £4.88
8Y6F StarTech.com 1m White Micro USB Cable - A to Micro B In Stock £2.91
8Y6F StarTech.com 2m White Micro USB Cable - A to Micro B In Stock £5.05
8Y6F StarTech.com 0.5m White Micro USB Cable - A to Micro B In Stock £2.60
Length: 3m
Price Range Ex VAT: 0 - 50
