StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F
Quicklinx: 8Y6FWS00 Mfr#: USBEXTPAA3MW
Length: 3m
30 In Stock
£6.37 ex VAT
£7.64 inc VAT
Extend the length of your USB 2.0 cable by up to 3m. The USBEXTPAA3MW 3m White USB 2.0 Extension Cable features a USB ''A'' male connector and a USB ''A'' female connector, enabling you to extend the connection distance between your USB 2.0 devices by up to 1-meter - allowing for better placement of your peripheral devices, or adding flexibility to your existing USB ports.
The cable features thin USB connector moldings which allow you to simplify your connections, and plug into tight fitting locations.
  • Durable construction
    The cable's molded design and strain relief feature ensure that it can withstand daily use without damage, making it a reliable choice for extending USB connections.
  • Efficient data transfer
    Designed with double shielding, the cable minimizes interference and allows for stable data transfer rates, accommodating various USB devices seamlessly.
  • Flexible connectivity
    With a length of 3 m, this extension cable provides the flexibility needed to reach distant USB devices or ports without sacrificing performance.
  • Environmental compliance
    This USB extension cable is compliant with RoHS standards, ensuring that it adheres to environmentally friendly practices during production.
StarTech.com 3m White USB 2.0 Extension Cable Cord - A to A - USB Male to Female Cable - 1x USB A (M), 1x USB A (F) - White, 3 meter (USBEXTPAA3MW) - USB extension cable - USB to USB - 3 m
USB extension cable
Double shielded
Molded, strain relief
Length
3 m
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
White
P/N: MSDREADU2OTG, USBEXTPAA1MW, USBEXTPAA2MW, USBPAUB1MW, USBPAUB2MW, USBPAUB50CMW, UUSBOTG
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
3 m
White
Connector
USB / USB 2.0, RoHS
8Y6F StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
8Y6F StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
8Y6F StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
8Y6F StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.23
8Y6F StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £6.37
8Y6F StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £5.73
8Y6F StarTech.com 2m White Micro USB Cable - A to Micro B In Stock £6.34
8Y6F StarTech.com 0.5m White Micro USB Cable - A to Micro B In Stock £5.13
Length: 3m
