StarTech.com 3m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9F5YWS00 Mfr#: N6PATC3MWH
Length: 3m
Colour: White
£3.56 ex VAT
£4.27 inc VAT
Express delivery Order within the next 18 hours for delivery on Tuesday
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC3MWH Cat 6 Patch Cable (3m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable white PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 3m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC3MWH) - patch cable - 3 m - white
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
3 m
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
9F5Y StarTech.com 3m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.80
9F5Y StarTech.com 3m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.52
9F5Y StarTech.com 3m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £1.94
9F5Y StarTech.com 3m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.80
9F5Y StarTech.com 3m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.80
9F5Y StarTech.com 3m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.56
9F5Y StarTech.com 3m Yellow Cat6 Patch Cable In Stock £4.19
9F5Y StarTech.com 3m Green Cat6 Patch Cable In Stock £4.20
Length: 3m
Colour: White
Stock Status: In stock
