Create a clutter free workstation by connecting your USB-C computer directly to a HDMI display, without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television, or projector. The adapter offers a connection distance of up to 3 m (10 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 3 m (10 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For shorter installations, StarTech.com also offers a 1 m (3 ft.) USB-C to HDMI cable (CDP2HD1MBNL) and 2 m (6 ft.) USB-C to HDMI cable (CDP2HD2MBNL), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
- StarTech.com 10ft (3m) USB C to HDMI Cable, 4K 60Hz USB Type C to HDMI 2.0 Video Adapter Cable, Thunderbolt 3 Compatible, Laptop to HDMI Monitor/Display, DP 1.2 Alt Mode HBR2 Cable, Black - 4K USB-C Video Cable (CDP2HD3MBNL) - adapter cable - HDMI / USB - 3 m
- Cable
- Adapter cable - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Length
- 3 m
- Black
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- HDMI - male (output)
- Displayport 1.2/Thunderbolt 3
- 4K60Hz (3840 x 2160) support
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- Cable Type
- Adapter cable 4K60Hz (3840 x 2160) support
- Interface Supported
- HDMI / USB
- Length
- 3 m
- HBR2 audio support, DisplayPort Alternate Mode support, 7.1 channel Surround Sound
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Apple MacOS, Linux, Android, Google Chrome OS, Windows 10, Apple iPadOS
- Connector
- 19 pin HDMI Type A - male (output)
- FCC, RoHS, HDCP 2.2, HDCP 1.4
- 80 g
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 90 g
- Limited warranty - 3 years
- Designed For
- P/N: TB4CDOCK
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £7.79 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.69 |
StarTech.com 2m USB C to HDMI Cable - Black | In Stock | £26.55 |
StarTech.com 1m USB C to HDMI Cable - Black | In Stock | £26.93 |
StarTech.com 3m USB C to HDMI Cable - Black | In Stock | £26.60 |
StarTech.com 1m USB C to HDMI Cable - White | In Stock | £22.46 |
StarTech.com 3ft (1m) USB C to HDMI Cable 4K 60Hz /HDR10 - USB-C to HDMI | In Stock | £17.16 |
StarTech.com 6ft (2m) USB C to HDMI Cable 4K 60Hz / HDR10 - USB-C to HDMI | In Stock | £17.96 |
StarTech.com 9.8ft (3m) USBC to HDMI Cable 4K USB-C HDMI Media Convertor | In Stock | £24.53 |
StarTech.com 16ft (5m) USB C to HDMI Cable 4K USB-C to HDMI Monitor Conve | In Stock | £26.26 |
