StarTech.com 3m USB-C Charging Cable
Quicklinx: HVMLWS00 Mfr#: USB2CC3MBKE
Hurry, only 3 left in stock!
£6.79 ex VAT
£8.14 inc VAT
The StarTech.com 3 m USB-C Charging Cable is a high-performance solution designed to meet the needs of modern device charging and data transfer. With its support for USB Power Delivery (60 W) and a 3 A rated current, this cable ensures your devices charge quickly and safely. The 480 Mbps data rate makes file transfers swift and efficient, ideal for both professional and personal use.
Constructed for durability, it boasts a 10,000 insertions lifespan, polyamide housing, and strain relief, ensuring it can withstand daily wear and tear. The cable also features comprehensive EMI protection and a minimum bend radius of 8 mm, safeguarding your devices against electromagnetic interference while maintaining flexibility. Its halogen-free, shielded design further emphasizes safety and environmental consciousness. Whether you're at home, in the office, or on the go, this USB-C cable from StarTech.com is the reliable choice for connecting and charging your devices.
  • Durable design
    Built to withstand over 10,000 insertions, this 3 m USB-C charging cable is designed for durability and longevity, ensuring a secure connection every time. Its polyamide housing and strain relief feature add an extra layer of durability, making it a reliable choice for daily use.
  • High-speed charging and syncing
    Supporting Power Delivery 2.0 and a 60 W 3 A power delivery, this cable facilitates fast charging for your devices. Additionally, with a 480 Mbps data rate, it ensures quick and efficient data syncing between devices, making it an ideal solution for keeping your gadgets charged and ready to go.
  • Enhanced protection
    Featuring EMI protection and a minimum bend radius of 8 mm, this cable is designed to safeguard against electromagnetic interference, ensuring a stable connection. The aluminum mylar foil with braid shielding further enhances its protection against external signals.
StarTech.com 3m USB-C Charging Cable, USB C Cable, 60W 3A PD - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
USB-C cable
Shielded
Halogen-free, passive cable, USB Power Delivery (60W), Power Delivery 2.0 support, sync and charge, strain relief, EMI protection, 480 Mbps data rate, polyamide housing, fast charging support, 10000 insertions lifespan, minimum bend radius 8 mm
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
5 / 9 / 12 / 15 / 20 V
Rated Current
3 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
24/30
Rated Voltage
Rated Current
3 A
Plated Connector
Nickel
Length
3 m
Outside Diameter
3.5 mm
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
90 g
