The StarTech.com 3 m (9.8 ft) White USB-A to USB-C Charging Cable is designed to meet a variety of charging and data transfer needs. Compliant with USB 2.0 standards, this cable supports a data rate of 480 Mbps, ensuring efficient data transfer for compatible devices. The strain relief feature adds durability, while the aluminum mylar foil and braid shielding provides EMI protection for stable connectivity. With a 3 A rated current, it supports USB Fast Charge at 15 W, allowing for quick charging to keep devices powered. Constructed with high-quality thermoplastic elastomer (TPE), this cable is halogen-free and built to withstand up to 10,000 insertions, offering longevity and reliability. Whether syncing data or charging devices, this cable combines performance with a flexible length, making it suitable for home or office use. The nickel-plated connectors contribute to conductivity, ensuring a reliable connection every time.
                Durable designThe cable features a strain relief mechanism and EMI shielding, enhancing durability against wear and tear while ensuring stable connectivity during use.
                High-speed data transferCapable of data rates up to 480 Mbps, this cable allows for rapid syncing of files between devices, making it suitable for users who require efficiency.
                High-performance chargingWith a rated current of 3 A and support for USB Fast Charge at 15 W, this cable ensures devices charge quickly and efficiently, minimizing downtime.
                Environmentally friendlyThis halogen-free cable is compliant with RoHS standards, making it a safer choice for the environment while also meeting performance needs.
                Long-lasting lifespanDesigned for durability, the cable can handle up to 10,000 insertions, ensuring reliability over time for everyday use.
- StarTech.com 3m (9.8ft) White USB-A to USB-C Charging Cable/Cord, M/M - USB-C cable - USB to 24 pin USB-C - 3 m
- USB-C cable
- Charge and sync, halogen-free, passive cable, USB Fast Charge (15W), 480 Mbps data rate, strain relief, 10000 insertions lifespanins, EMI protection
- Length
- 3 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- Rated Current
- 3 A
- USB / USB 2.0
- White
- Limited lifetime warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 23/28
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 3 m
- Outside Diameter
- 4 mm
- White
- 95 g
- Connector
- USB / USB 2.0, RoHS
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 100 g
