Charge your power-hungry mobile devices with this 24 AWG Micro-USB cable. Tired of being attached to the wall when charging and using your phone or tablet?
The USBAUB3MBK Micro USB cable offers 3 meters in cable length so you can charge your device in comfort and from a distance. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
Charge your device even while you're taking notes in a boardroom, catching up on emails in a hotel room, or reading in a coffee shop. The 3-meter long charge cable overcomes distance restrictions and lets you stay connected even while charging.
Provide full charging power, with no loss of charge time, even at distances of up to 10 feet (3 meters) away from your charger. The heavier gauge (24/30 AWG) wire lets you charge your mobile devices without slowing down charge time - allowing you to stay connected and charge at the same speed as you would using a shorter cable.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
- StarTech.com 3m 10 ft Long Micro-USB Charge-and-Sync Cable -M/M - USB to Micro USB Charging Cable - 24 AWG (USBAUB3MBK) - USB cable - Micro-USB Type B to USB - 3 m
- USB cable
- Technology
- Shielded
- Molded, sync and charge
- Length
- 3 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Nickel
- Length
- 3 m
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 0.5m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £4.31 |
StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £5.47 |
StarTech.com 1m Mobile Charge Sync USB to Slim Micro USB Cable - M/M | In Stock | £4.67 |
StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £4.58 |
StarTech.com 3m USB / Slim Micro USB Cable | In Stock | £5.80 |
