StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - SC
Quicklinx: 7Y1RWS00 Mfr#: 50FIBLCSC3
Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCSC3 3m LSZH LC to SC Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com 3m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/SC - OM2 - LC to SC Fiber Patch Cable - network cable - 3 m
Network cable
Duplex fibre optic
Type of Fibre Optics
Multimode
Length
3 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
2 x SC multi-mode - male
P/N: US100A20FXSC, US1GA30SXSC
Network Cable Type
Network cable
Duplex fibre optic
Multimode
50 / 125 micron
Length
3 m
Connector
7Y1R StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - SC In Stock £13.40
7Y1R StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - SC In Stock £14.33
