Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM3M 3m Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
High-quality connectivity
Experience reliable and high-quality connectivity with the StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Cable, featuring gold-plated connectors for optimal signal transfer and corrosion resistance. -
Enhanced viewing experience
Designed to support DisplayPort 4k, this cable ensures you enjoy vibrant visuals and flawless audio, making it perfect for high-resolution gaming, streaming, or professional design work. -
Durable design
Constructed with an aluminum mylar foil shielding and a robust 32 AWG wire, this cable is built to withstand the rigors of daily use while ensuring consistent performance.
- StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Cable DisplayPort 4k - DisplayPort cable - 3 m
- DisplayPort cable
- Technology
- Shielded
- Length
- 3 m
- Connector
- DisplayPort - male
- Connector (Second End)
- Mini DisplayPort - male
- RoHS
- Black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Gold
- Length
- 3 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS
