StarTech.com 3m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M
Quicklinx: 7RWTWS00 Mfr#: HDMM3MHS
Length: 3m
20 In Stock
£12.20 ex VAT
£14.64 inc VAT
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMM3MHS 3-meter High Speed HDMI Cable with Ethernet supports the advanced capabilities of the High-Definition Multimedia Interface, including Ethernet data inter-connectivity with compatible HDMI-enabled products, and is fully backward compatible with older HDMI-capable devices.
The cable features gold-plated HDMI (male) connectors which help to ensure a high quality digital connection capable of transmitting high-definition video and multi-channel audio between devices such as Blu-Ray Disc players, HDTVs, DVD Players, DVRs, stereo receivers and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
All StarTech.com High Speed HDMI Cables are expertly designed and constructed of top quality materials to deliver dependable high-definition performance.
  • High-performance connectors
    Featuring 19-pin HDMI Type-A connectors on both ends, this cable supports compatibility with a variety of devices, ensuring seamless connectivity and high-quality signal transfer.
  • Enhanced durability
    The sturdy PVC jacket protects the internal wiring and provides flexibility, making it easy to manage and install in any environment.
  • 3D and UHD support
    This cable transmits 3D content and Ultra HD video, providing an enhanced visual experience for movies and games.
  • Efficient data transfer
    The HDMI Ethernet Channel feature allows for shared network access between devices, making it efficient to connect multiple devices without the need for additional cables.
StarTech.com 3m High Speed HDMI Cable w/ Ethernet Ultra HD 4k x 2k - HDMI cable with Ethernet - 3 m
Cable
American Wire Gauge (AWG)
28
Length
3 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC), 3D-Transmission
Cable Type
28
Jacket Material
PVC
Length
3 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
7RWT StarTech.com 1m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.66
7RWT StarTech.com 2m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.38
7RWT StarTech.com 3m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £12.20
7RWT StarTech.com 15 m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £51.34
7RWT StarTech.com 10m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £34.45
7RWT StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.68
Length: 3m
