StarTech.com 3m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M
Quicklinx: 8G56WS00 Mfr#: HDADMM3M
Length: 3m
£10.02 ex VAT
£12.02 inc VAT
Connect an HDMI Micro-equipped smartphone or portable device up to 3m away from your HDMI-capable TV or display. The HDADMM3M High Speed Cable with Ethernet (3m) features one HDMI (A) male connector and one HDMI Micro (D) connector, enabling you to connect devices with an HDMI Micro port to a display/device with a standard HDMI port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology.
The HDMI/HDMI Micro cable features high-quality gold-tipped connectors that ensure peak connectivity.
  • Robust shielding for clear signals
    This HDMI cable features advanced shielding technology with aluminum mylar foil and braid, significantly reducing the chances of interference and ensuring a high-quality signal for audio and video needs.
  • Long-lasting construction
    The PVC jacket protects the internal wiring of the cable, providing added durability and ensuring that it withstands everyday wear and tear while maintaining optimal performance.
  • Gold-plated connectors for reliability
    The 19-pin connectors are gold-plated to increase conductivity and resist corrosion, leading to more stable connections and better performance in data transmission.
  • Versatile connectivity options
    With a standard HDMI Type-A connector on one end and a micro HDMI Type D connector on the other, this cable allows for flexible connections between a variety of devices, enhancing usability.
  • Supports advanced features
    This cable supports HDMI Ethernet Channel (HEC) and 3D transmission, making it suitable for high-definition content streaming and enhancing the viewing experience.
StarTech.com 3m High Speed HDMI® Cable with Ethernet - HDMI to HDMI Micro - M/M - 3 Meter HDMI (A) to HDMI Micro (D) Cable (HDADMM3M) - HDMI cable with Ethernet - 3 m
Cable
Shielded
American Wire Gauge (AWG)
32
Length
3 m
Connector
HDMI - male
Connector (Second End)
19 pin micro HDMI Type D - male
HDMI Ethernet Channel (HEC), 3D-Transmission
Cable Type
Shielded
32
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
8G56 StarTech.com 1m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M In Stock £7.68
8G56 StarTech.com 2m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M In Stock £8.54
8G56 StarTech.com 0.5m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M In Stock £6.40
Length: 3m
