Deliver high-performance 10 Gigabit network connections, free of noise and EMI/RFI interference. This Cat6a cable meets or exceeds all Category 6a cable specifications to ensure reliable 10Gb network connections. The cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise, providing the perfect solution for fast and safe network connections.
This 3-meter gray patch cable is perfect for standard applications such as connecting from a wall jack to your laptop docking station or desktop computer.
For easier network installations, the Cat6a patch cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
Each cable is tested for up to 500MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Constructed with 100% copper and foil-shielded, twisted-pair wiring, this cable was built for quality performance. The cable is designed to keep the data signals traveling through your network free from interference and is perfect in environments that are prone to large amounts of EMI.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
High-performance connectivity
This cable supports STP technology that reduces crosstalk and enhances data transmission quality for efficient network performance. -
Versatile power support
Ready for Power over Ethernet (PoE), this cable allows for data and power transmission, simplifying installation and setup. -
Durable and reliable design
The aluminum-polyester foil shielding and strain relief features ensure long-lasting durability and connection stability in various environments. -
Easy installation features
The snagless connector design prevents cable snags, allowing for smoother connections and easier handling during installation. -
Environmentally compliant
Manufactured in compliance with RoHS and WEEE standards, this cable adheres to environmental safety regulations, making it a responsible choice.
- StarTech.com 3m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Grey, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT3MGR) - patch cable - 3 m - grey
- Patch cable - CAT 6a
- Technology
- Shielded twisted pair (STP)
- Shielding Material
- Aluminium-polyester foil
- Wires per Cable
- 8 wires
- Snagless, strain relief, PoE ready, RFI/EMI shielding
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 25
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Length
- 3 m
- 100 g
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, WEEE - up to 500 MHz
StarTech.com 3m Black Cat6a Cable STP | In Stock | £13.29 |
StarTech.com 3m Blue Cat6a Cable STP | In Stock | £15.35 |
StarTech.com 3m Gray Cat6a Cable STP | In Stock | £15.45 |
