StarTech.com 3m Gray Cat6 SFTP Cable
Quicklinx: BMPTWS00 Mfr#: N6SPAT3MGR
Length: 3m
Colour: Grey
29 In Stock
£9.71 ex VAT
£11.65 inc VAT
Deliver high-performance Gigabit network connections, free of noise and EMI/RFI interference. This 3-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. And the cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise to provide the perfect solution for fast and safe network connections.
Constructed with 100% copper and foil shielded twisted-pair wiring, this cable was built for quality performance. The cable is designed to protect the data traveling through your network and is perfect in environments with a large amount of EMI. The results are faster speeds and improved data transmission.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For easier cable runs, the snagless connectors protect the RJ45 clips during installation, making them less prone to snagging or breaking. This ensures a sturdy connection by preventing the cable from becoming loose from the plug.
Plus, the molded boots offer strain relief that stops the RJ45 connector termination points from bending at sharp angles, which reduces the risk of damage to the cable that could decrease network performance.
  • Reliable connection
    This CAT6 Ethernet cable ensures a stable connection for networking tasks, making it ideal for personal and professional environments.
  • Durable construction
    The molded connectors and snagless design help prevent damage during installation, ensuring a long-lasting cable.
  • High-speed performance
    With a tested frequency of up to 500 MHz, this cable supports fast data transfers, essential for modern Internet usage.
  • Compatibility
    Designed with standard RJ-45 connectors, it is compatible with most networking devices, making it versatile for various setups.
StarTech.com 3m CAT6 Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6 10GbE SFTP Network Cable w/Strain Relief, Grey, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 26AWG (N6SPAT3MGR) - patch cable - 3 m - grey
Patch cable - CAT 6
Shielded foiled twisted pair (SFTP)
Wires per Cable
8 wires
Molded, snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
3 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B - up to 500 MHz
BMPT StarTech.com 3m Gray Cat6 SFTP Cable In Stock £9.71
BMPT StarTech.com 2m Grey Cat6 SFTP Cable In Stock £7.96
BMPT StarTech.com 1m Gray Cat6 SFTP Cable In Stock £7.58
BMPT StarTech.com 5m Grey Cat6 SFTP Cable In Stock £11.93
BMPT StarTech.com 0.5m Gray Cat6 SFTP Cable In Stock £6.45
Length: 3m
Colour: Grey
