Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM3M 3m DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 3m DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
- StarTech.com 3m DVID Dual Link Cable M/M - DVI cable - 3 m
- DVI cable - dual link
- Length
- 3 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- RoHS
- Black
- Limited lifetime warranty
- DVI cable
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Dual link
- Plated Connector
- Nickel
- Length
- 3 m
- Black
- Connector
- 24+1 pin digital DVI - male
- RoHS
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.78 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £11.28 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.86 |
StarTech.com 5m DVI-D Dual Link Cable – M/M | In Stock | £18.00 |
StarTech.com 1 ft DVI-D to 2x DVI-D Digital Video Splitter Cable - M/F | In Stock | £13.54 |
StarTech.com 2m DVI-D Dual Link Cable – M/M | In Stock | £9.65 |
StarTech.com 3m DVI-D Dual Link Cable – M/M | In Stock | £12.31 |
StarTech.com 1m DVI-D Dual Link Cable – M/M | In Stock | £8.34 |
