Charge your ASUS Transformer/Slider Tablet up to 3m distance from your power source. The USB2ASDC3M 3m ASUS Transformer USB Cable features one USB Type 'A' male connector and one (40-pin) ASUS male connector, delivering a simple way to connect your ASUS Eee Pad Transformer (TF101, Prime, etc.), ASUS Transformer Pad (Infinity, etc.) or ASUS Eee Pad Slider to a USB-capable computer.
This 3-meter long USB cable for ASUS tablets is twice as long as the standard supplied cable, and allows you to connect your ASUS Pad at further distances from your PC, or Mac Computer for data transfers or from an available power source for charging.
For convenience, this versatile ASUS tablet cable can be connected to a computer USB port for data transfers while you are working. Or you can connect the cable to the USB power adapter which was supplied with your ASUS Pad, for simple charging from an available (wall) power outlet.
This ASUS Transformer USB Cable is designed and constructed for maximum durability, making it a dependable replacement for damaged or misplaced data / charging cables.
- StarTech.com 3m Dock Connector to USB Cable ASUS Transformer Pad / Eee Pad - charging / data cable - 3 m
- Cable
- Charging / data cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 30/32
- Length
- 3 m
- Connector
- ASUS 40-pin Dock Connector - male
- Connector (Second End)
- USB - male
- Limited lifetime warranty
- Designed For
- ASUS Transformer Pad TF300T, TF300TG, TF300TL
- Cable Type
- Technology
- Double shielded
- 30/32
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 3 m
- Plated Connector
- Nickel
- Recommended Use
- Tablet
- Black
- Connector
- 4 pin USB Type A - male
- RoHS
- Limited warranty - lifetime
- Designed For
