StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 8377WS00 Mfr#: DISPL3M
Length: 3m
Hurry, only 2 left in stock!
£15.38 ex VAT
£18.45 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices. The DISPL3M 3m DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
  • Secure Connection
    The latched connectors ensure that the DisplayPort cable remains securely plugged in, preventing accidental disconnections.
  • High-Resolution Support
    This cable supports up to 4K resolution, allowing for stunning visuals in any multimedia setup.
  • Durable Construction
    Made with aluminum mylar foil and braid shielding, this cable is designed to withstand everyday use while providing excellent video quality.
  • Reduced Interference
    The shielded design minimizes signal interference, ensuring a stable and uninterrupted connection for high-definition displays.
  • Environmentally Friendly
    The cable is compliant with RoHS standards, making it a safe choice for both users and the environment.
StarTech.com 3m Certified DisplayPort 1.2 Cable M/M with Latches DP 4k - DisplayPort cable - 3 m
DisplayPort cable
Shielded
Latched, molded
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS, NEC-CMG
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched, molded
Length
3 m
Connector
20 pin DisplayPort - male
RoHS, NEC-CMG
8377 StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £13.69
8377 StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £16.52
8377 StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.34
8377 StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £5.83
8377 StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £15.38
8377 StarTech.com 7m DisplayPort Cable with Latches - M/M In Stock £11.31
Length: 3m
