StarTech.com 3m CAT8 Ethernet Cable, LSZH
Quicklinx: J1LPWS00 Mfr#: NLBL-3M-CAT8-PATCH
Hurry, only 1 left in stock!
£27.60 ex VAT
£33.12 inc VAT
The 3m Blue CAT8 Ethernet Cable by StarTech.com offers a robust solution for high-speed network connectivity. Built to support data transfer rates of up to 40 Gbps, this patch cable is compliant with standards including IEEE 802.3bt and IEEE 802.3ba, ensuring reliability in performance. With eight pure bare copper conductors and a shielded design featuring aluminum mylar foil with braid, this cable minimizes electromagnetic interference while providing excellent durability and strain relief. Additionally, its low smoke zero halogen jacket enhances safety in various environments. Designed for high demands, the cable is capable of supporting 100W Power over Ethernet (PoE++) and can withstand up to 750 mating cycles. It is also flame-retardant to further enhance its safety profile. The snagless design ensures easy installation without the hassle of jacks snagging. This is an ideal choice for advanced networking setups, delivering seamless connectivity whether for home use or professional environments.
  • Durable Build
    This cable is constructed with pure bare copper conductors and aluminum mylar foil shielding to ensure robustness and reliability in high-speed networking.
  • High Speed Performance
    Capable of supporting data transfer rates up to 40 Gbps, this cable meets the requirements for advanced networking setups.
  • Versatile Compatibility
    Supports 100W PoE++ and is compliant with various standards, allowing for flexible use in different networking scenarios.
  • Safe Operation
    With a low smoke zero halogen jacket and flame-retardant features, this cable ensures safety during operation.
  • Easy Installation
    The snagless design prevents jacks from snagging, simplifying the installation process and ensuring a clean setup.
StarTech.com 3m Blue CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 3 m - blue
Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
S/FTP
Wiring Scheme
T568B
Shielding Material
Wires per Cable
8 wires
Snagless, halogen-free, passive cable, up to 40 Gbps, 100W PoE++ support, pure bare copper conductors, strain relief, test fluke pass, EMI protection, 750 mating cycles, flame retardant
Length
3 m
Diameter
5.6 mm
Core / Cladding Diameter
50 micron
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Wiring Scheme
T568B
Shielding Material
Jacket Material
Low Smoke Zero Halogen (LSZH)
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
50 micron
Plated Connector
Gold
Length
3 m
Diameter
5.6 mm
Blue
Connector
RJ-45 - male
RJ-45 - male
TIA/EIA T568B - up to 2000 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
2 cm
Shipping Weight
131 g
50 °C
