The 3m Blue CAT8 Ethernet Cable by StarTech.com offers a robust solution for high-speed network connectivity. Built to support data transfer rates of up to 40 Gbps, this patch cable is compliant with standards including IEEE 802.3bt and IEEE 802.3ba, ensuring reliability in performance. With eight pure bare copper conductors and a shielded design featuring aluminum mylar foil with braid, this cable minimizes electromagnetic interference while providing excellent durability and strain relief. Additionally, its low smoke zero halogen jacket enhances safety in various environments. Designed for high demands, the cable is capable of supporting 100W Power over Ethernet (PoE++) and can withstand up to 750 mating cycles. It is also flame-retardant to further enhance its safety profile. The snagless design ensures easy installation without the hassle of jacks snagging. This is an ideal choice for advanced networking setups, delivering seamless connectivity whether for home use or professional environments.
Durable Build
This cable is constructed with pure bare copper conductors and aluminum mylar foil shielding to ensure robustness and reliability in high-speed networking. -
High Speed Performance
Capable of supporting data transfer rates up to 40 Gbps, this cable meets the requirements for advanced networking setups. -
Versatile Compatibility
Supports 100W PoE++ and is compliant with various standards, allowing for flexible use in different networking scenarios. -
Safe Operation
With a low smoke zero halogen jacket and flame-retardant features, this cable ensures safety during operation. -
Easy Installation
The snagless design prevents jacks from snagging, simplifying the installation process and ensuring a clean setup.
- StarTech.com 3m Blue CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 3 m - blue
- Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Shielding Material
- Aluminum mylar foil with braid
- Wires per Cable
- 8 wires
- Snagless, halogen-free, passive cable, up to 40 Gbps, 100W PoE++ support, pure bare copper conductors, strain relief, test fluke pass, EMI protection, 750 mating cycles, flame retardant
- Length
- 3 m
- Diameter
- 5.6 mm
- Core / Cladding Diameter
- 50 micron
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- 50 micron
- Plated Connector
- Gold
- Length
- 3 m
- Diameter
- 5.6 mm
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- TIA/EIA T568B - up to 2000 MHz
- Shipping Width
- 22 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 131 g
- 0 °C
- 50 °C
