StarTech.com 3m CAT6a Ethernet Cable LSZH - White
Quicklinx: H15NWS00 Mfr#: NLWH-3M-CAT6A-PATCH
Length: 3m
Colour: White
20 In Stock
£14.82 ex VAT
£17.78 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Available in a variety of lengths and colors, the shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • High-performance transmission
    This cable supports speeds of up to 10 Gbps, making it suitable for high-bandwidth applications while maintaining performance across networks.
  • Safe and environmentally friendly
    The Low Smoke Zero Halogen (LSZH) jacket reduces harmful emissions in case of fire, providing a safer alternative in both residential and commercial installations.
  • Reliable shielding
    The S/FTP construction minimizes EMI/RFI interference and Near-End Crosstalk, ensuring uninterrupted data flow for improved network stability.
  • Easy installation
    Equipped with strain reliefs and snagless connectors, this cable allows for straightforward installation while minimizing the risk of cable damage.
  • Meets industry standards
    This Ethernet cable is compliant with various standards including RoHS and ETL, ensuring quality and reliability in networking applications.
StarTech.com 3m CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 3 m - white
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
3 m
108.4 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
2 cm
Shipping Weight
117.1 g
Length: 3m
Colour: White
