StarTech.com 3m CAT6a Ethernet Cable LSZH - Blue
Quicklinx: H159WS00 Mfr#: NLBL-3M-CAT6A-PATCH
Length: 3m
Colour: Blue
20 In Stock
£12.73 ex VAT
£15.27 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 3m - Blue - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • High-speed performance
    This cable supports data transmission speeds of up to 10 Gbps, making it suitable for high-speed network demands.
  • Safe materials
    Constructed with Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes toxic smoke emissions, enhancing safety during installation.
  • Interference reduction
    S/FTP technology helps minimize Near-End Crosstalk (NEXT) and ensures a reliable connection by shielding against external interference.
  • Power over Ethernet
    Supports up to 100 W PoE++ for powering connected devices, simplifying network installations by eliminating the need for separate power sources.
  • Durable design
    Features strain relief, copper conductors, and gold-plated connectors to enhance durability and performance in demanding environments.
StarTech.com 3m CAT6a Ethernet Cable - Blue - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 3 m - blue
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
3 m
108.4 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
2 cm
Shipping Weight
117.1 g
Length: 3m
Colour: Blue
