Connect your USB 3.0 devices over longer distances. The USB3SAB3MBK 3m Black USB 3.0 A-to-B cable allows you to connect your USB 3.0 type-B devices, such as your hard drive enclosures, card readers, docking stations and video capture devices, up to 3 meters away from your computer.
The USB 3.0 cable features high quality Shielded Twisted Pair (STP) construction, which helps to prevent electro-magnetic interference and ensures reliable data communication.
The 3m cable provides guaranteed quality and reliability.
Efficient data transfer
Enjoy a data rate of 5 Gbps, allowing for quick and seamless file transfers between devices. -
Durable construction
Molded connectors are designed to withstand wear and tear, ensuring long-lasting performance. -
USB 3.0 compliance
This cable adheres to USB 3.0 standards, enabling high-speed connectivity for compatible devices. -
Optimal signal quality
With a 28 AWG specification, this cable minimizes signal loss for improved data integrity. -
Flexible length
The 3m length provides ample room for connecting devices without compromising on organization.
- StarTech.com 3m Black SuperSpeed USB 3.0 Cable A to B M/M - USB cable - USB Type B to USB Type A - 3 m
- USB cable
- Technology
- Shielded twisted pair (STP)
- Molded, 5 Gbps data rate
- Length
- 3 m
- Connector
- 9 pin USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- American Wire Gauge (AWG)
- 28
- Length
- 3 m
- Black
- Connector
- USB 3.0, RoHS
StarTech.com 3m Black SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £9.10 |
