StarTech.com 3m Black SuperSpeed USB 3.0 Cable A to B - M/M
Quicklinx: 9G6CWS00 Mfr#: USB3SAB3MBK
Length: 3m
30 In Stock
£9.99 ex VAT
£11.98 inc VAT
Connect your USB 3.0 devices over longer distances. The USB3SAB3MBK 3m Black USB 3.0 A-to-B cable allows you to connect your USB 3.0 type-B devices, such as your hard drive enclosures, card readers, docking stations and video capture devices, up to 3 meters away from your computer.
The USB 3.0 cable features high quality Shielded Twisted Pair (STP) construction, which helps to prevent electro-magnetic interference and ensures reliable data communication.
The 3m cable provides guaranteed quality and reliability.
  • Efficient data transfer
    Enjoy a data rate of 5 Gbps, allowing for quick and seamless file transfers between devices.
  • Durable construction
    Molded connectors are designed to withstand wear and tear, ensuring long-lasting performance.
  • USB 3.0 compliance
    This cable adheres to USB 3.0 standards, enabling high-speed connectivity for compatible devices.
  • Optimal signal quality
    With a 28 AWG specification, this cable minimizes signal loss for improved data integrity.
  • Flexible length
    The 3m length provides ample room for connecting devices without compromising on organization.
StarTech.com 3m Black SuperSpeed USB 3.0 Cable A to B M/M - USB cable - USB Type B to USB Type A - 3 m
USB cable
Shielded twisted pair (STP)
Molded, 5 Gbps data rate
Length
3 m
Connector
9 pin USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
USB cable
American Wire Gauge (AWG)
28
Length
3 m
Connector
USB 3.0, RoHS
9G6C StarTech.com 3m Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £9.99
Length: 3m
