StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F
Quicklinx: 8G44WS00 Mfr#: MXT1003MBK
Length: 3m
Hurry, only 2 left in stock!
£5.03 ex VAT
£6.03 inc VAT
Extend the connection between your DB9 serial devices by up to 3m. The MXT1003MBK Black Serial Extension Cable (3m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
  • Reliable connectivity
    This serial extension cable is designed to provide stable and dependable connections between devices, making it suitable for various applications that rely on serial communication.
  • Efficient signal transmission
    The shielded technology minimizes electromagnetic interference, ensuring that data is transmitted clearly and accurately without disruptions.
  • Durable construction
    Featuring nickel-plated connectors, this cable enhances electrical conductivity and promises increased longevity and resistance to wear.
  • Environmentally friendly design
    This product adheres to RoHS compliant standards, ensuring that it is created with consideration for environmental safety and sustainability.
  • Versatile applications
    The male to female configuration allows for effective connectivity between different devices, making this extension cable suitable for a wide range of setups.
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - DB9 RS232 Serial Extension Cable - Male to Female Cable (MXT1003MBK) - serial extension cable - DB-9 to DB-9 - 3 m
Serial extension cable
Shielded
Length
3 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
P/N: 1P3FPC-USB-SERIAL, IC232TTL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232IS, ICUSB232PRO, ICUSB232V2
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
3 m
Connector
RoHS
8G44 StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.15
8G44 StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £3.00
8G44 StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.03
8G44 StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.12
Length: 3m
