StarTech.com 3m Aqua OM4 LC Fiber Cable
Quicklinx: CZD8WS00 Mfr#: 450FBLCLC3
Length: 3m
Colour: Aqua
Select:
£22.65 ex VAT
£27.18 inc VAT
Connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. This fiber optic cable lets you connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. The OM4 cable supports Vertical Cavity Surface Emitting Laser (VCSEL) and LED light sources and is backward compatible with your existing 50/125 equipment.
This Aqua OM4 duplex multimode fiber cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. It's ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
  • High-performance design
    Featuring laser-optimized multimode fiber, this cable enhances data transmission efficiency and minimizes signal loss over distances.
  • Advanced technology
    Equipped with VCSEL array technology, this cable provides effective data handling and increased bandwidth for demanding applications.
  • Durable construction
    The low smoke zero halogen jacket material ensures safety and durability, making it suitable for various environments where safety is a concern.
  • Efficient connectivity
    With both left and right connectors utilizing LC multi-mode interfaces, the cable allows for seamless connections with compatible devices.
  • Robust performance
    With a tested frequency of up to 3500 MHz, this cable is designed to meet the needs of high-speed networking applications.
StarTech.com Aqua OM4 Duplex Multimode Fiber - 3m/ 9 ft - 100 Gb - 50/125 - OM4 Fiber - LC to LC Fiber Patch Cable (450FBLCLC3) - network cable - 3 m - aqua
Network cable - OM4
Duplex fibre optic
Type of Fibre Optics
Multimode
Laser-optimized multimode fibre (LOMMF), VCSEL array technology
Length
3 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
Network Cable Type
Network cable - OM4
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
50 / 125 micron
Length
3 m
Aqua
Connector
Up to 3500 MHz
CZD8 StarTech.com 1m Aqua OM4 LC Fiber Cable In Stock £17.33
CZD8 StarTech.com 2m Aqua OM4 LC Fiber Cable In Stock £18.58
CZD8 StarTech.com 5m Aqua OM4 LC Fiber Cable In Stock £20.77
CZD8 StarTech.com 3m Aqua OM4 LC Fiber Cable In Stock £21.65
CZD8 StarTech.com 10m OM4 LC Multimode Duplex Fiber Optic Patch Cable Aqua In Stock £38.07
CZD8 StarTech.com 7m OM4 LC Multimode Duplex Fiber Optic Patch Cable - Aqua In Stock £30.82
CZD8 StarTech.com 15m OM4 LC-LC Multimode Duplex Fiber Optic Patch Cable Aqua In Stock £50.09
Length: 3m
Colour: Aqua
