Connect your MSA compliant 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
 - StarTech.com MSA Uncoded Compatible 3m 10G SFP+ to SFP+ Direct Attach Breakout Cable Twinax, 10 GbE SFP+ Copper DAC 10 Gbps Low Power Passive Transceiver Module DAC, 10GE Breakout Cable - Lifetime Warranty (SFP10GPC3M) - direct attach cable - 3 m - black
 - Direct attach cable - SFF-8431/SFF-8432
- Technology
 - Twinaxial
- Shielding Material
 - Copper
 - Passive cable, Hot-pluggable
- Length
 - 3 m
- Connector
 - SFP+
- Connector (Second End)
 - SFP+
 - Black
 - Limited lifetime warranty
- Network Cable Type
- Technology
 - Twinaxial
 - Copper
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 30
- Impedance
 - 100 Ohm
- Length
 - 3 m
 - 1.4 cm
 - 1.2 cm
 - 130 g
 - Black
- Connector
 - SFP+
 - SFP+
 - FCC, RoHS, WEEE, MSA, RCM
 - 0 °C
 - 70 °C
                        StarTech.com 1m 3.3ft 10G SFP+ DAC Cable | In Stock | £25.39 |
                        StarTech.com 2m 6.6ft 10G SFP+ DAC Cable | In Stock | £30.53 |
                        StarTech.com 3m 9.8ft 10G SFP+ DAC Cable | In Stock | £33.56 |
