StarTech.com 3m 9.8ft 10G SFP+ DAC Cable
Quicklinx: D9VLWS00 Mfr#: SFP10GPC3M
Length: 3m
Colour: Black
10 In Stock
£33.56 ex VAT
£40.27 inc VAT
Connect your MSA compliant 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
StarTech.com MSA Uncoded Compatible 3m 10G SFP+ to SFP+ Direct Attach Breakout Cable Twinax, 10 GbE SFP+ Copper DAC 10 Gbps Low Power Passive Transceiver Module DAC, 10GE Breakout Cable - Lifetime Warranty (SFP10GPC3M) - direct attach cable - 3 m - black
Direct attach cable - SFF-8431/SFF-8432
Twinaxial
Shielding Material
Copper
Passive cable, Hot-pluggable
Length
3 m
Connector
SFP+
Connector (Second End)
SFP+
Network Cable Type
Twinaxial
Shielding Material
Copper
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Length
3 m
1.4 cm
1.2 cm
130 g
Connector
SFP+
SFP+
FCC, RoHS, WEEE, MSA, RCM
70 °C
D9VL StarTech.com 1m 3.3ft 10G SFP+ DAC Cable In Stock £25.39
D9VL StarTech.com 2m 6.6ft 10G SFP+ DAC Cable In Stock £30.53
D9VL StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £33.56
Length: 3m
Colour: Black
