StarTech.com 3m 9.8ft 10G SFP+ AOC Cable
Quicklinx: D9VFWS00 Mfr#: SFP10GAOC3M
Length: 3m
Colour: Black
Select:
£113.13 ex VAT
£135.75 inc VAT
Connect your Cisco compliant 10GbE SFP+ network devices with this cost-effective, active optical cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than SFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point in-rack and across-rack network switch or server connections.
StarTech.com Cisco SFP-10G-AOC3M Compatible 3m/9.84ft 10G SFP+ to SFP+ Active Optical Fiber, 10Gbps SFP Plus/Mini GBIC/Transceiver Module Cable, Cisco Firepower ASR1000, 10GE SFP+ Cable - Lifetime Warranty (SFP10GAOC3M) - 10GBase direct attach cable - 3 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Fibre optic
Active cable
Length
3 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
Cisco SFP-10G-AOC3M
Network Cable Type
Fibre optic
Jacket Material
PVC
Active cable
Length
3 m
130 g
Connector
SFP+ - latched
SFP+ - latched
Cisco SFP-10G-AOC3M
FCC, RoHS, MSA
70 °C
D9VF StarTech.com 3m 9.8ft 10G SFP+ AOC Cable In Stock £113.13
D9VF StarTech.com 5m 16.4ft 10G SFP+ AOC Cable In Stock £129.70
Length: 3m
Colour: Black
Stock Status: In stock
