Connect your Cisco compliant 10GbE SFP+ network devices with this cost-effective, active optical cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than SFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point in-rack and across-rack network switch or server connections.
- StarTech.com Cisco SFP-10G-AOC3M Compatible 3m/9.84ft 10G SFP+ to SFP+ Active Optical Fiber, 10Gbps SFP Plus/Mini GBIC/Transceiver Module Cable, Cisco Firepower ASR1000, 10GE SFP+ Cable - Lifetime Warranty (SFP10GAOC3M) - 10GBase direct attach cable - 3 m - black
- 10GBase direct attach cable - SFF-8431/SFF-8432
- Technology
- Fibre optic
- Active cable
- Length
- 3 m
- Connector
- SFP+ - latched
- Connector (Second End)
- SFP+ - latched
- Black
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-10G-AOC3M
- Limited lifetime warranty
- Network Cable Type
- Technology
- Fibre optic
- Jacket Material
- PVC
- Active cable
- Length
- 3 m
- 130 g
- Black
- Connector
- SFP+ - latched
- SFP+ - latched
- FCC, RoHS, MSA
- 0 °C
- 70 °C
StarTech.com 3m 9.8ft 10G SFP+ AOC Cable | In Stock | £128.51 |
