StarTech.com 3m 10ft USB 3.0 A to A Cable
Quicklinx: C588WS00 Mfr#: USB3SAA3MBK
Length: 3m
28 In Stock
£7.87 ex VAT
£9.44 inc VAT
Connect USB 3.0 USB-A devices to a USB hub or to your computer. This USB 3.1 Gen 1 (5Gbps) cable, also known as a USB 3.0 cable, lets you connect your USB-A devices as needed throughout your workspace. With a connection distance of up to 3 meters (10 feet), you can organize your PC and USB hub, or other USB-A devices, to match your configuration needs.
Plus, this high-quality cable features Shielded Twisted Pair (STP) construction, which helps to prevent electro-magnetic interference and ensure reliable data communication.
  • Durable design
    Molded connectors ensure sturdiness, making this USB cable less prone to wear over time.
  • High-speed connectivity
    With a data transfer rate of up to 5 Gbps, this cable provides a fast and efficient connection for various devices.
  • Convenient length
    Measuring 10 ft, this cable allows for greater flexibility in device placement, reducing the need for additional extensions.
  • Strain relief feature
    Designed with strain relief, this cable minimizes damage and enhances its lifespan, making it a reliable choice.
StarTech.com 3m 10 ft USB 3.0 Cable - A to A - M/M - Long USB 3.0 Cable - USB 3.1 Gen 1 (5 Gbps) (USB3SAA3MBK) - USB cable - USB Type A to USB Type A - 3 m
USB cable
Shielded twisted pair (STP)
Molded, strain relief, 5 Gbps data rate
Length
3 m
Connector
9 pin USB Type A - male
Connector (Second End)
USB 3.0
P/N: HB30C1A1CPD, HB30C3A1CFBW, HB30C3A1CST, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, HB30C5A2CSC, HB30C5A2CST, SV231DPU34K, SV431DPU3A2, USB32VGAEH, USB3EXT6INBK
USB cable
Length
3 m
Connector
USB 3.0
C588 StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £11.80
C588 StarTech.com 3m USB 3.0 Active Extension Cable - M/F In Stock £69.06
C588 StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £83.61
C588 StarTech.com 10m USB 3.0 Active Extension Cable - M/F In Stock £112.84
C588 StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
C588 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.24
C588 StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £12.94
C588 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.11
C588 StarTech.com 6in USB 3.0 Extension Cable In Stock £5.54
Length: 3m
