Connect USB 3.0 USB-A devices to a USB hub or to your computer. This USB 3.1 Gen 1 (5Gbps) cable, also known as a USB 3.0 cable, lets you connect your USB-A devices as needed throughout your workspace. With a connection distance of up to 3 meters (10 feet), you can organize your PC and USB hub, or other USB-A devices, to match your configuration needs.
Plus, this high-quality cable features Shielded Twisted Pair (STP) construction, which helps to prevent electro-magnetic interference and ensure reliable data communication.
                Durable designMolded connectors ensure sturdiness, making this USB cable less prone to wear over time.
                High-speed connectivityWith a data transfer rate of up to 5 Gbps, this cable provides a fast and efficient connection for various devices.
                Convenient lengthMeasuring 10 ft, this cable allows for greater flexibility in device placement, reducing the need for additional extensions.
                Strain relief featureDesigned with strain relief, this cable minimizes damage and enhances its lifespan, making it a reliable choice.
- StarTech.com 3m 10 ft USB 3.0 Cable - A to A - M/M - Long USB 3.0 Cable - USB 3.1 Gen 1 (5 Gbps) (USB3SAA3MBK) - USB cable - USB Type A to USB Type A - 3 m
- USB cable
- Technology
- Shielded twisted pair (STP)
- Molded, strain relief, 5 Gbps data rate
- Length
- 3 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30C1A1CPD, HB30C3A1CFBW, HB30C3A1CST, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, HB30C5A2CSC, HB30C5A2CST, SV231DPU34K, SV431DPU3A2, USB32VGAEH, USB3EXT6INBK
- USB cable
- Technology
- Length
- 3 m
- Black
- Connector
- USB 3.0
- Designed For
|  | StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £12.04 |
|  | StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £81.57 |
|  | StarTech.com 10m USB 3.0 Active Extension Cable - M/F | In Stock | £110.10 |
|  | StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.53 |
|  | StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.73 |
|  | StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £11.77 |
|  | StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.94 |
|  | StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.72 |
