Deliver fast, reliable, data transfers, safely over high end networking equipment. The A50FBLCLC3 3m 850nm Laser-Optimized Multimode Fiber (LOMMF) Aqua Cord features 50/125 micron fiber for high-speed, high bandwidth data transmissions over 10 Gigabit Ethernet and Fiber Channel networks - the perfect solution for fiber cable runs between multiple backbone switches, hubs and routers as well as higher end networking equipment.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM3) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Efficient performance
This fiber optic cable is designed with laser-optimized multimode fiber, providing efficient data transmission at speeds up to 10 Gb. -
Safe installation
With a Low Smoke Zero Halogen jacket, the cable reduces toxic smoke emissions in case of fire, contributing to a safer working environment. -
Reliable connectivity
Equipped with dual LC male connectors, this cable ensures stable and reliable connections in various networking setups. -
Compliance and durability
This cable meets both OM3 standards and RoHS compliance, offering durability and environmental safety for professional environments.
- StarTech.com 3m Fiber Optic Cable - 10 Gb Aqua - Multimode Duplex 50/125 - LSZH - LC/LC - OM3 - LC to LC Fiber Patch Cable - patch cable - 3 m - aqua
- Patch cable - OM3
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Halogen-free, Laser-optimized multimode fibre (LOMMF)
- Length
- 3 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Designed For
- P/N: 455883B21ST, EXSFP10GESRS, J9150AST, J9152AST, MASFP10GBSR, SFP10GBLRMST, SFP10GBSRST, SFP10GLRMST, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST
- Network Cable Type
- Patch cable - OM3
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Length
- 3 m
- Aqua
- Connector
- RoHS
- Designed For
StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC
