StarTech.com 3m (10ft) Computer Power Cord
Quicklinx: GVKNWS00 Mfr#: 713E-3M-POWER-CORD
Length: 3m
46 In Stock
£6.17 ex VAT
£7.40 inc VAT
3m (10ft) Computer Power Cord, 18AWG, EU Schuko to C13 Power Cord, 10A 250V, Black Replacement AC Cord, TV/Monitor Power Cable, Schuko CEE 7/7 to IEC 60320 C13 Power Cord - PC Power Supply Cable (713E-3M-POWER-CORD).
  • Flexible design
    The 3 m (10 ft) Computer Power Cord features an 18AWG cable that is highly flexible, making it easy to install in tight spaces. The angled left connector design further enhances its flexibility, allowing for a seamless connection to devices.
  • Durable construction
    Constructed with a durable PVC jacket and molded connectors, this power cord is built to withstand the rigors of everyday use. Its robust design ensures long-lasting performance and reliability.
  • High compatibility
    Featuring a Schuko CEE 7/7 to IEC 60320 C13 connection, this power cord is compatible with a wide range of devices, including TVs, monitors, and PC power supplies. Its universal design makes it a versatile replacement or spare power cable.
  • Safety compliant
    Adhering to RoHS, VDE, VW-1, and WEEE standards, the power cord meets strict safety and environmental regulations. This compliance ensures a safe power solution for your devices and peace of mind for you.
StarTech.com 3m (10ft) Computer Power Cord, 18AWG, EU Schuko to C13 Power Cord, 10A 250V, Black Replacement AC Cord, TV/Monitor Power Cable, Schuko CEE 7/7 to IEC 60320 C13 Power Cord - PC Power Supply Cable (713E-3M-POWER-CORD) - power cable - power CEE 7/7 to power IEC 60320 C13 - 3 m
Power cable
Molded, flexible
Length
3 m
Europe
Connector
Power CEE 7/7 - plug - angled
Connector (Second End)
Power IEC 60320 C13
Rated Voltage
AC 250 V
Rated Current
10 A
Power cable
Jacket Material
PVC
American Wire Gauge (AWG)
18
Rated Voltage
AC 250 V
Rated Current
10 A
Molded, flexible
Length
3 m
Outside Diameter
6.8 mm
Europe
Connector
Power IEC 60320 C13
VDE, RoHS, WEEE, VW-1
Shipping Width
30.5 cm
Shipping Depth
14 cm
Shipping Height
25 cm
Shipping Weight
279 g
Length: 3m
