StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
Quicklinx: 84MMWS00 Mfr#: MDP2DPMM3MW
Length: 3m
£9.23 ex VAT
£11.07 inc VAT
Connect your DisplayPort monitor to a Mini DisplayPort source. The MDP2DPMM3MW, 3-meter, Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DisplayPort (male) connector on one end, and a DisplayPort (male) connector on the other, allowing you to connect any Mini DisplayPort-enabled laptop (including Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
StarTech.com 3m 10 ft White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k with HBR2 support - Mini DP to DP Cable (MDP2DPMM3MW) - DisplayPort cable - 3 m
DisplayPort cable
Shielded
Drain wire
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
White
P/N: CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, HD2DP, TB2DOCK4K2DP
DisplayPort cable
Shielded
Shielding Material
Aluminum mylar foil
American Wire Gauge (AWG)
32
Plated Connector
Gold
Drain wire
Length
3 m
White
Connector
20 pin DisplayPort - male
RoHS
84MM StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.24
84MM StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.45
84MM StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £10.00
84MM StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £8.54
84MM StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £14.11
Length: 3m
