StarTech.com 3m (10 ft) White CL3 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 98DPWS00 Mfr#: HD3MM3MW
Length: 3m
£12.43 ex VAT
£14.91 inc VAT
Create Ultra HD in-wall HDMI cable installations, for applications requiring CL3-rated cables. The HD3MM3MW 3m (10ft) High Speed HDMI Cable is CL3-Rated for in-wall installations, and features two gold-plated HDMI (male) connectors to provide a dependable high quality HDMI to HDMI connection between devices such as Blu-Ray Disc players, HDTVs, DVD Players, stereo receivers, projectors and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
StarTech.com 3m/10 ft CL3 Rated HDMI Cable with Ethernet, In Wall Rated HDMI Cable 4K 30Hz, UHD High Speed HDMI Cable 10.2 Gbps Bandwidth, 4K Ultra HD HDMI 1.4 Video / Display Cable, 30AWG - Long White HDMI Cable - HDMI cable - 3 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
30/32
Length
3 m
White
Connector
HDMI - male
Connector (Second End)
HDMI - male
CL3 rated jacket, in wall mounting
Cable Type
HDMI cable
Double shielded
30/32
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Gold
White
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
98DP StarTech.com 3m (10 ft) White CL3 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £12.43
98DP StarTech.com 7m (23 ft) White CL3 In-wall High Speed HDMI Cable – HDMI to HDMI - M/M In Stock £19.26
Length: 3m
