StarTech.com 3in1 Multiport to HDMI Adapter
Quicklinx: GFGVWS00 Mfr#: CDPHDMDP2HD
£23.13 ex VAT
£27.75 inc VAT
Digital AV Adapter - 4K 60Hz + HDR - 2 Channel Audio
This multiport to HDMI adapter provides multiple host options, connecting your USB-C , HDMI or Mini DisplayPort device to an HDMI display. This digital AV adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
With brighter colors and greater contrast, the adapter is ideal for:
• Creating eye-catching visuals for photography, videography, cinematography
• Delivering enriched presentations
Single Adapter Solution
With three popular input connections, this 4K HDMI AV adapter eliminates the need for multiple adapters and is compatible with the most common devices, ensuring you can connect wherever you go. The adapter can also conveniently be left connected to HDMI displays in boardrooms or conference rooms permanently, helping to reduce setup time.
True 4K at 60Hz and HDR
The 3 in 1 HDMI adapter is fully compatible with HDMI 2.0b specification, supporting resolutions up to 4K 60Hz (3840 x 2160) and bandwidths up to 18Gbps. The video converter is also backward compatible with lower resolutions including HD 1080p, making it ideal for your office or home office setup.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
The adapter also outputs 2-channel audio no matter what host you're connected to, ensuring a seamless AV experience.
Hassle-Free Setup
To ensure easy operation and installation, this multi connector adapter supports a plug & play setup with any OS, including macOS, Windows, Ubuntu, Chrome and Android.
This multiport AV adapter is backed by a 3-year StarTech.com warranty, and free lifetime technical support.
  • 3-in-1 adapter
    This multiport to HDMI adapter features three common host port options including USB C, HDMI or Mini DisplayPort to seamlessly connect one laptop or tablet to an HDMI monitor, TV or projector in a boardroom, office or conference room.
  • 4K resolution
  • HDR support
StarTech.com 3-in-1 Multiport to HDMI Adapter, 4K 60Hz USB-C, HDMI or Mini DisplayPort to HDMI Converter for Conference Room, Digital AV Video Adapter to Connect HDMI Monitor/Display - USB Type-C/HDMI/mDP to HDMI (CDPHDMDP2HD) - adapter - Mini DisplayPort / HDMI / USB
Cable
Adapter - Mini DisplayPort / HDMI / USB
Max Output Resolution
3840 x 2160 - 60 Hz
Connectors
24 pin USB-C - male (input) , HDMI - male (input) , Mini DisplayPort - male (input)
Connectors (Second End)
HDMI - female (output) , Micro-USB Type B (power only) - female
Displayport 1.2/Thunderbolt 3
4K60Hz (3840 x 2160) support
3-year warranty
Cable Type
Adapter 4K60Hz (3840 x 2160) support
Interface Supported
HDR support, DisplayPort Alternate Mode support
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connectors
24 pin USB-C - male (input) , 19 pin HDMI Type A - male (input) , Mini DisplayPort - male (input)
19 pin HDMI Type A - female (output) , 5 pin Micro-USB Type B (power only) - female
USB-A to Micro-USB cable
FCC, RoHS
5.5 cm
8 cm
2 cm
110 g
Shipping Width
21.8 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
191.7 g
Limited warranty - 3 years
GFGV StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.34
GFGV StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.86
GFGV StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £19.66
GFGV StarTech.com 5m 15ft Premium 4K HDMI Cable In Stock £24.09
GFGV StarTech.com 7m 23ft Premium 4K HDMI Cable In Stock £35.52
GFGV StarTech.com 0.5m Premium 4K HDMI Cable In Stock £9.55
