StarTech.com 3ft USB4 Cable, USB-C 40 Gbps
Quicklinx: HDGTWS00 Mfr#: CC1M-40G-USB-CABLE
Length: 1m
30 In Stock
£20.36 ex VAT
£24.43 inc VAT
3ft (1m) USB4 Cable, USB-IF Certified USB-C Cable, 40 Gbps, USB Type-C Data Transfer Cable, 100W Power Delivery, 8K 60Hz, Compatible w/Thunderbolt 4/3/USB 3.2 - USB C to C cable (CC1M-40G-USB-CABLE).
  • USB-IF certified
    USB4 cable is USB-IF certified with E-Marker chip, for reliable and consistent Power Delivery output to USB-C hosts and devices, supports DisplayPort 1.4 with DSC, compliant with PCIe 3.0 for external PCIe chassis/storage.
  • Quality construction
    Nickel-plated connectors with robust strain reliefs for durability, coaxial wire with Mylar shield for enhanced EMI protection, TPE cable jacket is environmentally friendly, non-toxic, halogen-free, and RoHS compliant.
  • Applications
    This versatile USB-C cable enables connectivity and charging across compatible USB, Thunderbolt 4/3, and DP Alt Mode devices, ideal for high speed data transfer or docking stations, dock and charge a USB-C laptop over a single connection.
  • Establish fast and stable power/data connections
    This USB4 Type-C cable is USB-IF certified for guaranteed USB-C compatibility. It reliably delivers consistent transfer rates and up to 100 W PD output. It is ideal for 40 Gbps data transfer to external USB-C-enabled external storage devices or as a single-cable connection from a USB-C dock to a laptop. This cable has undergone rigorous USB-IF compliance testing to meet USB4 specifications. This includes electrical and mechanical standards which ensures a reliable, high-quality cable for USB-C devices.
  • Power a USB-C laptop
    Power and charge a USB-C laptop, such as Apple MacBook, Lenovo ThinkPad, or Microsoft Surface with up to 100 W output over USB Power Delivery 3.0. Connect the USB4 cable from a laptop to a USB-C wall charger or docking station.
StarTech.com 3ft (1m) USB4 Cable, USB-IF Certified USB-C Cable, 40 Gbps, USB Type-C Data Transfer Cable, 100W Power Delivery, 8K 60Hz, Compatible w/Thunderbolt 4/3/USB 3.2 - USB C to C cable (CC1M-40G-USB-CABLE) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Shielded
4K support, 8K support, USB Power Delivery (100W), up to 40 Gbps data transfer rate, strain relief, halogen free, DisplayPort 1.4 with DSC
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 2.0 / USB 3.1 / USB 3.2 / USB4 / Thunderbolt 3 / Thunderbolt 4
USB-C cable
Shielded
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30/34
Plated Connector
Nickel
Length
1 m
Outside Diameter
4.95 mm
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 2.0 / USB 3.1 / USB 3.2 / USB4 / Thunderbolt 3 / Thunderbolt 4, RoHS, USB-IF, EMI, DisplayPort 1.4, PCIe 3.0
HDGT StarTech.com 1m USB4 Cable, USB-C 40 Gbps In Stock £22.14
HDGT StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps In Stock £19.09
Length: 1m
