3ft (1m) USB4 Cable, USB-IF Certified USB-C Cable, 40 Gbps, USB Type-C Data Transfer Cable, 100W Power Delivery, 8K 60Hz, Compatible w/Thunderbolt 4/3/USB 3.2 - USB C to C cable (CC1M-40G-USB-CABLE).
USB-IF certified
USB4 cable is USB-IF certified with E-Marker chip, for reliable and consistent Power Delivery output to USB-C hosts and devices, supports DisplayPort 1.4 with DSC, compliant with PCIe 3.0 for external PCIe chassis/storage. -
Quality construction
Nickel-plated connectors with robust strain reliefs for durability, coaxial wire with Mylar shield for enhanced EMI protection, TPE cable jacket is environmentally friendly, non-toxic, halogen-free, and RoHS compliant. -
Applications
This versatile USB-C cable enables connectivity and charging across compatible USB, Thunderbolt 4/3, and DP Alt Mode devices, ideal for high speed data transfer or docking stations, dock and charge a USB-C laptop over a single connection. -
Establish fast and stable power/data connections
This USB4 Type-C cable is USB-IF certified for guaranteed USB-C compatibility. It reliably delivers consistent transfer rates and up to 100 W PD output. It is ideal for 40 Gbps data transfer to external USB-C-enabled external storage devices or as a single-cable connection from a USB-C dock to a laptop. This cable has undergone rigorous USB-IF compliance testing to meet USB4 specifications. This includes electrical and mechanical standards which ensures a reliable, high-quality cable for USB-C devices. -
Power a USB-C laptop
Power and charge a USB-C laptop, such as Apple MacBook, Lenovo ThinkPad, or Microsoft Surface with up to 100 W output over USB Power Delivery 3.0. Connect the USB4 cable from a laptop to a USB-C wall charger or docking station.
- StarTech.com 3ft (1m) USB4 Cable, USB-IF Certified USB-C Cable, 40 Gbps, USB Type-C Data Transfer Cable, 100W Power Delivery, 8K 60Hz, Compatible w/Thunderbolt 4/3/USB 3.2 - USB C to C cable (CC1M-40G-USB-CABLE) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Technology
- Shielded
- 4K support, 8K support, USB Power Delivery (100W), up to 40 Gbps data transfer rate, strain relief, halogen free, DisplayPort 1.4 with DSC
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB 2.0 / USB 3.1 / USB 3.2 / USB4 / Thunderbolt 3 / Thunderbolt 4
- Black
- USB-C cable
- Technology
- Shielded
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30/34
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 4.95 mm
- Black
- Connector
- USB 2.0 / USB 3.1 / USB 3.2 / USB4 / Thunderbolt 3 / Thunderbolt 4, RoHS, USB-IF, EMI, DisplayPort 1.4, PCIe 3.0
StarTech.com Thunderbolt 3 Ethernet Adapter | In Stock | £224.09 |
