This USB 3.2/3.1 Gen 2 10Gbps USB-C cable lets you connect your USB Type-C devices for syncing, charging and powering your devices. The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
Power your USB-C devices
With up to 5A (100W) of power delivery, you can power a USB-C laptop, such as your Apple MacBook or Microsoft Surface Book. Simply connect the cable to your USB-C laptop and to a USB-C wall charger. You can use this USB Type-C cable to power your USB-C hard drive from the USB-C port on your laptop. -
Charge your mobile devices
When used with devices that support PD 3.0, this cable charges up to 20V and 5A for a maximum of 100W. It can decrease your charge time and make sure your mobile devices are ready, whenever you need them. -
Deliver 8K Video with DisplayPort 1.4 Alt Mode
The cable supports 8K 30Hz video with DisplayPort 1.4 and is backward compatible to connect your docking station or laptop to a monitor that supports 4K or 1080p resolutions. -
Provide superior connections with USB-IF certified cables
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 3.2/3.1 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable, high-quality cable for all your USB-C devices.
- StarTech 3ft (1m) USB C Cable 10Gbps, USB-IF Certified USB-C Cable, USB 3.1/3.2 Gen 2 Type-C Cable, 100W (5A) Power Delivery Charging, DP Alt Mode, USB C to C Cord, Charge & Sync - Thunderbolt 3 Compatible (USB31CCV1M) - USB-C cable - USB-C to USB-C - 1 m
- USB-C cable
- 4K support, EMI protection, DisplayPort Alternate Mode support, Power Delivery (PD) technology, outer diameter 4.8 mm, 10 Gbps data rate
- Cable Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3
- Grey, black
- 2-year warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30/32
- Plated Connector
- Nickel
- Cable Length
- 1 m
- Grey, black
- Connector
- USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3, RoHS, WEEE
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 14 cm
- Shipping Weight
- 95 g
- 2-year warranty
StarTech.com Rugged Right Angle USB-C Cable 1m | In Stock | £28.64 |
StarTech.com 3m Active USB-C Cable, USB 3.2 | In Stock | £48.60 |
