StarTech.com 3ft USB C Cable 10Gbps Gen2
Quicklinx: GJX0WS00 Mfr#: USB31CCV1M
Length: 1m
15 In Stock
£14.13 ex VAT
£16.95 inc VAT
This USB 3.2/3.1 Gen 2 10Gbps USB-C cable lets you connect your USB Type-C devices for syncing, charging and powering your devices. The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
  • Power your USB-C devices
    With up to 5A (100W) of power delivery, you can power a USB-C laptop, such as your Apple MacBook or Microsoft Surface Book. Simply connect the cable to your USB-C laptop and to a USB-C wall charger. You can use this USB Type-C cable to power your USB-C hard drive from the USB-C port on your laptop.
  • Charge your mobile devices
    When used with devices that support PD 3.0, this cable charges up to 20V and 5A for a maximum of 100W. It can decrease your charge time and make sure your mobile devices are ready, whenever you need them.
  • Deliver 8K Video with DisplayPort 1.4 Alt Mode
    The cable supports 8K 30Hz video with DisplayPort 1.4 and is backward compatible to connect your docking station or laptop to a monitor that supports 4K or 1080p resolutions.
  • Provide superior connections with USB-IF certified cables
    The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 3.2/3.1 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable, high-quality cable for all your USB-C devices.
StarTech.com 3ft (1m) USB C Cable 10Gbps, USB-IF Certified USB-C Cable, USB 3.1/3.2 Gen 2 Type-C Cable, 100W (5A) Power Delivery Charging, DP Alt Mode, USB C to C Cord, Charge & Sync - Thunderbolt 3 Compatible (USB31CCV1M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
4K support, Power Delivery (PD) technology, 10 Gbps data rate, DisplayPort Alternate Mode support, EMI protection, outer diameter 4.8 mm
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3
Black, grey
USB-C cable
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30/32
Plated Connector
Nickel
Length
1 m
Black, grey
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3, RoHS, WEEE
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
14 cm
Shipping Weight
95 g
GJX0 StarTech.com Rugged Right Angle USB-C Cable 1m In Stock £26.23
GJX0 StarTech.com 3m Active USB-C Cable, USB 3.2 In Stock £44.50
Length: 1m
