The 3 ft (1 m) White USB-A to USB-C Charging Cable from StarTech.com offers a reliable solution for both charging and data transfer. Designed to provide a quick and effective connection, this cable supports USB Fast Charge with a capacity of 15 W, ensuring devices can be powered up efficiently. Its 480 Mbps data rate enables seamless syncing of files between devices, making it ideal for everyday use. Built with durability in mind, this USB-C cable features aluminum mylar foil shielding to protect against EMI interference. The cable includes strain relief and a nickel-plated connector, allowing for up to 10,000 insertions, ensuring longevity in various applications. The halogen-free jacket made of thermoplastic elastomer (TPE) adds to its safe usage profile, complying with RoHS standards for environmental considerations.
Efficient charging capabilities
This cable supports USB Fast Charge with a rated current of 3 A, providing a rapid power source to keep devices charged and ready for use. -
High-speed data transfer
With a data rate of 480 Mbps, this cable facilitates fast and efficient syncing of files between devices, making it perfect for transferring data quickly. -
Robust and durable design
Engineered to last, the cable includes strain relief features and aluminum mylar foil shielding while withstanding up to 10,000 insertions. -
Environmentally friendly construction
Made with halogen-free materials, this cable complies with RoHS standards, indicating its reduced environmental impact. -
Versatile compatibility
Designed with a USB Type-A and USB-C connection, this cable is compatible with a wide range of devices, making it a flexible addition to any tech setup.
- StarTech.com 3ft (1m) White USB-A to USB-C Charging Cable/Cord, M/M - USB-C cable - USB to 24 pin USB-C - 1 m
- USB-C cable
- Charge and sync, halogen-free, passive cable, USB Fast Charge (15W), 480 Mbps data rate, strain relief, 10000 insertions lifespanins, EMI protection
- Length
- 1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- Rated Current
- 3 A
- USB / USB 2.0
- White
- Limited lifetime warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 24/32
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 3 mm
- White
- 21 g
- Connector
- USB / USB 2.0, RoHS
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 0.8 cm
- Shipping Weight
- 26 g
