This top screw locking USB-C 3.2/3.1 Gen 2 10Gbps cable lets you connect your USB Type-C devices for syncing, charging, and powering your devices. The USB-C cable is also compatible with Thunderbolt 3 ports, allowing you to connect and charge your USB-C devices using your Thunderbolt 3 laptop.
Reliable connection with screw locking USB-C
This cable features a single locking screw that can securely connect to your USB-C peripherals and can prevent accidental disconnection from your devices such as external hard drives or docking stations. The screw is designed to fit all devices that use a standard top screw locking input, such as StarTech.com's DK31C3HPD. The knurled screw can easily be removed from the cable completely allowing it to be used as a standard USB-C cable if required. -
Supports up to 100W (5A) with Power Delivery 3.0
With up to 100W (5A) of power delivery, you can power and charge a USB-C laptop, such as your Apple MacBook or Microsoft Surface Book. Simply connect the cable to your USB-C laptop and to a USB-C wall charger. -
Deliver 8K video with DisplayPort 1.4 Alt Mode
The cable supports 8K 30Hz video with DisplayPort 1.4 and is backward compatible to connect your docking station or laptop to a monitor that supports 4K or 1080p resolutions. -
Charge your mobile devices
When used with devices that support PD 3.0, this cable charges up to 20V and 5A for a maximum of 100W. It can decrease your charge time and make sure your mobile devices are ready, whenever you need them. -
Quality build
This cable is constructed with durable long-lasting, flexible TPE jacket and strain relief. It has been tested to withstand 4000+ bends. It is built with aluminum-mylar foil with 85% braid coverage and EMI shielding for improved signal integrity.
- StarTech.com 3ft 1m Top Screw Locking USB C Cable 10Gbps, USB 3.1/3.2 Gen 2 Type-C Cable, 100W (5A) Power Delivery Charging, DP Alt Mode, Single Screw Lock, USB-C to C Cord, Charge/Sync - Thunderbolt 3 Compatible (USB31CCTLKV1M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- 8K support, Power Delivery (PD) technology, 10 Gbps data rate, DisplayPort Alternate Mode support, EMI protection, outer diameter 4.8 mm
- Length
- 1 m
- Connector
- 24 pin USB-C - male - straight/locking
- Connector (Second End)
- USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3
- Black, grey
- 2-year warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30/32
- Plated Connector
- Nickel
- Length
- 1 m
- Black, grey
- Connector
- USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3, RoHS, WEEE
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 14 cm
- Shipping Weight
- 90 g
- 2-year warranty
StarTech.com Rugged Right Angle USB-C Cable 1m | In Stock | £27.96 |
