StarTech.com 3ft Slim Micro USB 3.0 Cable
Quicklinx: BJX0WS00 Mfr#: USB3AU1MRS
Length: 1m
Hurry, only 1 left in stock!
£4.17 ex VAT
£5.00 inc VAT
Express delivery Order within the next 36 minutes for delivery tomorrow
Position your USB 3.0 Micro devices with less clutter and according to your configuration needs, with a thin, more flexible cable. This slim, sturdy USB 3.1 Gen 1 (5 Gbps) cable, also known as a USB 3.0 cable, lets you position Micro-USB devices on your desk without the cable getting in the way. It's thinner and more flexible than standard cables, and features a right-angled Micro-USB connector that prevents awkward bends at the connection port.
Now you can arrange your desk according to what works best for you, without worrying about the cable bending awkwardly or straining too much to make a connection. This durable, lightweight cable is roughly half the thickness of a regular USB 3.0 cable, giving you the flexibility and freedom to place your devices as needed, with minimal clutter.
This versatile cable features a right-angled connector, which offers a more natural fit at the device connection point and helps prevent unnecessary strain and damage to the port.
Replace the cable that came with your Micro USB mobile device or keep one as a spare while traveling.
As well as being ideal for connecting to your desktop devices, this cable provides the perfect solution for charging and syncing your USB 3.0 Micro B-equipped phones and tablets.
The cable features a thin, yet sturdy connector molding, so you'll be able to connect to your phone or tablet without removing its protective case. Plus, the cable's right-angled Micro-USB connector lets you text, work or game on your mobile device even while it's charging, without the cable getting in the way.
StarTech.com 1m 3 ft Slim Micro USB 3.0 Cable M/M - Right-Angle Micro-USB - USB 3.0 A to Micro B - Angled Micro USB - USB 3.1 Gen 1 5Gbps (USB3AU1MRS) - USB cable - Micro-USB Type B to USB Type A - 1 m
USB cable
Shielded
Right-angled connector, sync and charge, 5 Gbps data rate
Length
1 m
Connector
10 pin Micro-USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: HB30A4AIB, HB30AM4AB, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HB31C4AB
USB cable
Shielded
American Wire Gauge (AWG)
26/32
Plated Connector
Nickel
Length
1 m
Connector
USB 3.0, RoHS
BJX0 StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £8.79
BJX0 StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £4.17
Length: 1m
Stock Status: While stocks last
Stock Status: Clearance
